1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Featured New NETGEAR Orbi Breaks $100 / Node Price Point
Discussion in 'NETGEAR AC Wireless' started by Julio Urquidi, Oct 15, 2019.
  1. Julio Urquidi
    Julio Urquidi News Editor
    Apr 12, 2016
    370
    NETGEAR's new Orbi Dual Band Mesh Wi-Fi System is a three-node mesh Wi-Fi kit that lists for $229.99, or a little over $70 per node, making it cheaper than Google WiFi.
    The new Orbi system is an AC1200 class dual-band Wi-Fi 5 (802.11ac) design, which means it's the first Orbi to not have a dedicated 5 GHz backhaul radio. The RBK13 kit includes one Wi-Fi router and two satellites, each powered by a quad-core 710 MHz processor, 256MB flash and 512MB RAM.
    Each node's dual-band radio supports maximim link rates of 400 Mbps @ 2.4 GHz and 800 Mbps @ 5 GHz, AC MU-MIMO downlink, implicit and explicit beamforming and "seamless" roaming between access points/nodes.
    Physical interfaces provided on the router node include two gigabit ethernet ports (one LAN and one WAN). The satellites do not have an Ethernet port, so cannot be connected via Ethernet backhaul.
    Other features include NETGEAR Armor for anti-virus, anti-malware, and data protection, Circle Smart Parental Control, Amazon Alexa and Google Assistant support and setup and management using NETGEAR's Orbi app for Android or iOS.
    Available now, the three-piece Netgear Orbi Dual Band Mesh Wi-Fi System is available through Netgear retailers and priced at $229.99.
    sd70mac likes this.
  2. gfondeur
    gfondeur Occasional Visitor
    Oct 4, 2019
    19
    It sounds like it can be a nice present for the holidays
    repulsive likes this.
  3. pete y testing
    pete y testing Very Senior Member
    Jul 12, 2011
    1,931
    victoria, australia
    just a note here , both of the above are subscription based services
    sd70mac and gfondeur like this.
  4. 10gig
    10gig Occasional Visitor
    Nov 25, 2018
    20
    Interestingly, the 3-pack wall plug system was on sale for only $170 yesterday. It's the one where you've got one regular base unit, and the two mesh units plug straight into outlets like the Plume: https://www.amazon.com/dp/B072ZN4PSB/?tag=snbforums-20
    I wouldn't pay $230 for an AC1200 dual-band system at this point. That's too close to the price of much more powerful mesh systems, and well above the price of numerous excellent conventional routers with much higher throughput.
