NextDNS Uninstall question
kmrafhsx
I noticed installing via the NextDNS script CLI causes following changes:
- disable DNSSEC
- disable DNS Rebind
- disable dnsmasq
If I decide to uninstall your service using the script and go back to Quad9 how do I re-enable DNSSEC, DNS Rebind and DNSMASQ? Does the script automatically do it with the uninstall?
ColinTaylor
Part of the Furniture
Maybe you should post your question to them via their website as the NextDNS author hasn't logged into these forums since August last year.
dave14305
NextDNS doesn’t change DNS nvram, but disables these things on the fly when dnsmasq starts and nextdns is active. So uninstalling should leave dnsmasq as you had it beforehand.
