openVpn client - ProtonVPN - error - SSL/TLS issue
tommy1
hi,
i have two profiles for protonVpn - one for particular server and another one for a country (set of few servers), with one there's constant 'connecting' and with country one "error - SSL/TLS issue", it used to work till now..
there was also "Error connecting - Authentication failed" message ovpn credentials are for sure correct.
merlin version 384.16
RMerlin
Asuswrt-Merlin dev
You need to disable IPv6 support in your OpenVPN clients.
pull-filter ignore "ifconfig-ipv6"
pull-filter ignore "route-ipv6"
tommy1
could you please define my openvpn clients ?
within merlin settings there's IPv6 in 'advanced settings' section where ipv6 traffic is disabled, but i'm assuming you're referring to sth else ?
Martineau
Part of the Furniture
see this post
tommy1
thanks! that worked out, initially it says connecting -> authentication failed -> and then suddenly says connected and i'm online, a bit unpredictable behavior but it works again,
my current "custom configuration" for that open vpn profile looks as follows:
remote-random
resolv-retry infinite
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
remote-cert-tls server
pull
fast-io
that is one UDP connection with one server, and there's another one TCP one for another IP in my home network that works in paralel where there are no issues, i didnt add there those additional ipv6 settings, i wonder why..
