JimmieNoName
I have an RT-N66U running Merlin 3.0.0.4.374.32 software. My cellphone company uses a hybrid wifi/cell system where, when wifi is unavailable, the call switches to cell. I'm using an HMA VPN, and when I try to make a cell call using wifi, I get an error message that SIP/UDP and SIP/TCP are blocked. The phone works fine for web browsing and such,and with the VPN turned off, but will not complete a call with it turned on. I'm assuming it has something to do with the firewall and closed ports. To make matters worse, I'm a novice when it comes to both VPN and cellphones making VOIP type calls. I've spent the better part of several weeks trying to solve this and am now at my wits end. Any help would be much appreciated.
Edit: In an effort to avoid anyone wasting their time trying to find a solution, I've decided not to pursue this any further. I'm afraid that even if it could be solved, the procedure would be above my level of expertise.
