drftnc240jm
I have been reading on these forums for a few days and have come up with a setup that I believe will meet all my needs. If you could critique or improve my setup it would be greatly appreciated.
The goal is to use the the internet from Building A and extend it Building B. On top of that, I would like to create a WLAN between the two buildings. The buildings are roughly 250 feet apart.
NEEDS:
- Both building will have to be able to access the WHS that will be located in Building A.
- A guest account that is accessible in both buildings (only internet access)
- UPnP capable for the WHS
- Have WPA2-PSK or Radius encryption
- Hide WLAN SSID
- No WDS involved
SETUP:
Building A: modem provided by ISP---> Engenius ESR9850 (Router w/ WHS, Printer, and one client connected via gigabit switch)---> Engenius EOR7550 (AP connected using PoE)
Building B: Engenius EOR7550 (Client Bridge)---> Engenius ECB9500 (AP)
Hardware will have the same ssid, channel, and password for the main account. A second vlan will be setup following the same method for the guest account.
Questions:
- Will this work properly for what I am trying to do?
- Will I only need 1 antenna per EOR7550? (for 802.11a/b/g devices)
- Will the internal 6dbi antennas of the EOR7550s be able to reach each other as long as they are in line of sight of each other? (distance would be about 150 feet, this antenna is for 802.11n)
- Is there a way to add a gigabit switch to the AP in Building B for a client and printer? (I am assuming not since there is only 1 rj45 port on the back and it will be connected to the bridge)
Thanks for any help and advice you may be able to provide.
NEEDS:
- Hide WLAN SSID
- No WDS involved
SETUP:
Questions:
