Just installed Asus/Merlin 3.0.0.4.374.38_1, reset to default, and have been resetting all settings manually. About halfway done checking (most things I've left to default).
A problem on the Advanced_WAN_Content.asp page (WAN/Internet Connection):
The username and password under the "Account Setting" section always default to the 2.4Ghz SSID and password - NOT the ISP user/password. EVEN IF YOU MANUALLY RESET THESE TWO FIELDS AND HIT APPLY - they default again to the 2.4Ghz SSID and password.
Knocked me off the internet for a minute, then quickly saw the problem.
NOTE - I printed out each "page" to make sure of settings, installed the firmware from my computer - after it rebooted, it came back up - things looked normal and worked - however, I followed the instructions for the 3.0.0.4.274.33 that said if coming from a version older then 3.0.0.4.374.xxx I needed to reset to default - then manually reconfigure. I was coming from a 3.0.0.4.372 version - so I reset, and have been reconfiguring manually.
