Problem on router login
HowTo
Good day
I have a problem with RT-AX86U router.
This is what I get when trying to log into the router.
Any suggestion how to solve this.
Did windows err_tunnel connection failed.
Did a router reset. Then it works ok for a moment or two. Then back to this.
Nope not one of them work.
Sounds like a DNS issue. Have you changed any DNS settings on the router from their default values?
Are you using a VPN or proxy server?
Does this problem happen on all devices or only this one PC?
What does this return on the client?
nslookup router.asus.com
"Are you using a VPN or proxy server?" really don't know what you asking? My fiber runs into ONT from their straight to ASUS router. I have fiber connection currently.
Can browse, but can't login into router.
"Does this problem happen on all devices or only this one PC?" did try to upgrade a router on the Asus network, fails every time.
This is what I got from your request, above.
Sorry for the late replies. I'm in South Africa.
Sorry, I don't understand your reply. I was asking whether you had tried to access the router's web interface on a completely different PC, and whether that also had to same problem. In other words, is this a problem that only effects one specific PC?
Will give it a bash in the morning on a different laptop.
Good day
It works on different laptop, I can excess Asus login screens.
Good day
Some browsers are forcing redirect to https:// now and by default the asus doesn't have that enabled. You can disable that in the browser settings.
Think this solved the issue
Gave permission ! not secure.
Tnx all to put me in the right direction.
Other picture gave this.
What that means?
