ducdeptrai1234
Just a good note about Entware in R7800: Even though the Voxel firmware itself is stable and good-performing, install Entware is totally worth it. The throughput increase dramatically, and it seems to perform even smoother than Voxel-only firmware. There is also a summarized tutorial for Entware from user Azimul Kabir Apu , which is very intuitive to follow:
You can use transmission without any problem if you install it on Entware. I had same problem with router transmission so I installed it on Entware and working flawlessly since then.
You can follow the following guide:
Connect to router through Telnet. Go to: www.routerlogin.net/debug.htm and activate Telnet Access.
Code:# Entware Installation (it will format the drive, so backup the drive if required) mkfs.ext4 -L optware -O ^metadata_csum,^64bit /dev/sda1 cd /tmp/mnt/sda1 wget https://www.voxel-firmware.com/Downloads/Voxel/Entware/entware-cortex-a15-3x-initial-generic.tar.gz tar -xzf entware-cortex-a15-3x-initial-generic.tar.gz reboot ls -l /opt/* # Check if above command shows entware directories or symlinks (bin, usr, share, var etc.)
Code:# Create swap file (optional) in /mnt/sda1or /mnt/sdb1or /mnt/sdc1 etc.: cd /mnt/sda1 dd if=/dev/zero of=swap bs=1024 count=1048576 mkswap swap chmod 0600 swap swapon swap reboot /opt/bin/opkg update /opt/bin/opkg upgrade
Enjoy.Code:# Disable Router Version of Transmission: nvram set transmission_disable=1 nvram commit # Install followings: /opt/bin/opkg install transmission-daemon-openssl /opt/bin/opkg install transmission-web-control /opt/etc/init.d/S88transmission stop # Change Transmission settings file as per your requirements, which is located at: /tmp/mnt/sda1/entware/etc/transmission/settings.json (/opt/etc/transmission/settings.json) # After changing execute following: /opt/etc/init.d/S88transmission start # Access Transmission from: 192.168.1.1:9091
