I have my remote desktop settings configured so that only local connections are allowed; port 80 is not forwarded to my desktop's static IP, so unless a device attempts to connect through LAN or over VPN, the connection fails.
If I'm physically outside my network, I establish a VPN connection from my iPhone or tablet using the built in ASUS OpenVPN server, then I can use the RDP client to connect to my computer. This works flawlessly on the stock ASUS firmware, but the connection fails using Merlin firmware. OpenVPN works, I draw a local IP from my LAN, and I can log into my router by entering its local IP, but Remote Desktop fails to connect.
Double checking to make sure the firmware is the issue, I've flashed back and forth between stock ASUS and Merlin firmware. Is this a bug, or was a setting added that I'm not aware of?
Thanks!
Edit- I should add that, using Merlin firmware, I was still able to connect to my desktop over RDP while connected to my network via wifi. However, connecting through VPN would not allow the RDP client to connect.
Thanks!
