Solved Rogue Tuya Device
BreakingDad
So I am getting this on my System Log / Wireless Log
The device is detected as a Tuya IOT device by Mac Vendor
It does not get an ip assigned to it, it's showing as 3(b) weird? and <not found> and has no flags and 0 connected time
As far as I am aware it is not a randomised mac, I have checked all our phones etc.
I am thinking it's a neighbours smart bulb crying for a connection, but why does it keep showing on my wireless log
It also jumps from main 2.4ghz to guest 2.4ghz
I have seen on the forum a couple of others have had this with the issue never really being solved.
Hoping one of you smart people can shed any light @SomeWhereOverTheRainBow
That said I just mac filtered the offender with guest and main so now not showing, but it still kinda "hurts my autism" that it was even showing in the first place on my network.
It does not get an ip assigned to it, it;s showing as 3(b) weird? and <not found> and has no flags and 0 connected time
Yea, I don't usually see things like this happen on my network. If it does, I typically don't have the time to observe it when it does.
That means the device is failing to associate even at the wifi level, so this can just be ignored.
Thank you will sleep better now.
