The big picture: 2 Asus routers - AC86U local and AX56U remote. Each router has a small (32GB) SSD attached to the USB 3 port.
I backup a small number of files to each router from their local networks. I run rsync (installed from Entware) through a cron job to backup remote files to the local router's storage.
That works well, but on the remote router on the Administration -> System tab I have SSH enabled on both the LAN and WAN interfaces.
On the local router VPN Client 4 connects to the OpenVPN server running on the remote router
What I'm trying to achieve is SSH through the VPN client 4 in order to have LAN only SSH on the remote router.
I used
Here is the outcome (with SSH on the LAN interface only on the remote router)
...and the outcome with both LAN and WAN SSH enabled on the remote:
I'm also using Selective Routing over the first 3 VPN clients and WAN and that works well. Skynet, unbound and Scribe running smoothly on the AC86U.
If required, I can provide the RPDB rules, prerouting and client ovpn information.
Any pointers and suggestions, please?
I used
as described at https://github.com/RMerl/asuswrt-merlin.ng/wiki/Policy-based-Port-routing-(manual-method).Example 4 "Services hosted on the router may also be routed via the VPN, ...
asmin@RT-AC86U:/tmp/mnt/asus/conf# ssh -p XXXX -i /jffs/dropbear/msg2drb_db asmin@10.8.0.1
ssh: Connection to asmin@10.8.0.1:XXXX exited: Connect failed: Connection refused
ASUSWRT-Merlin RT-AX56U 384.17_0 Sun Apr 26 02:27:47 UTC 2020
asmin@RT-AX56U:/tmp/home/root#
