Hi all,
thi is my first post in this forum.
I bought this router and i have updated it with the latest version of the Firmware merlin: 380.57
I happened that the router disconnects and makes me repeat the configuration with the message "Settings have been updated. Web page will now refresh. Changes have been made to the IP address or port number. You will now be disconnected from RT-AC68U. To access the settings of RT-AC68U, reconnect to the wireless network and use the updated IP address and port number".
I'm not sure but this happens after few minute when I unplug usb hard disk without unmount command.
Can be this the problem?
I have found a similar question on asus forum without solution:
I have the possibility to change this router with newest like RT-AC87U. Is it more stable?
Thank you
Thank you
