My RT-AC87U died unexpectedly today. Lost internet, checked the router and all LEDs were off, like it was powered off. The top of the unit was quite warm, almost hot, to the touch. I cycled the power switch several times and checked the power adapter output with a DC volt meter (19VDC). I let it cool down and tried again - nothing. I tried putting it into recovery mode by holding the Reset button in then plugging in power - nothing. An Asus router should not just spontaneously die right (or maybe they do)? So I removed 4 screws and pulled the top off hoping to find a blown internal fuse or some sign of heat damage or a burned component. Everything look perfect and if there is a fuse, its surface mount. So despite its internals looking brand new, it was still totally dead. Then I read a post on this forum that said try removing power and slowly cycling the power switch on and off about 10 times. I did that, plugged it back in, turned it on and it booted up! So maybe dust buildup in the power switch?
I have not yet connected to it to see if its functioning, but I can see both the 2..4GHz and 5GHz SSIDs, so its broadcasting. I just let it boot up and sit there with the top removed. There are 3 big heat sinks fastened to the main circuit board. If looking from the front, from left to right they are labelled SH3, SH2, and SH1. SH1 and SH3 are the same size, SH2 is larger. After powering it up and letting it sit for awhile, heat sink SH1 was getting too hot to comfortably touch. SH2 was warm but not alarming, and SH3 was a little warm. I also thought I caught a whiff of burnt electronics smell but it was very mild and I could not localize it. I can probably connect to it but I am concerned about why it suddenly shut down. Now I know why the top was so warm - there are 3 big heatsinks right below it. With the top off, heat sink SH1 is getting almost too hot to touch. Is this normal? I am worried maybe a cap or a voltage regulator is failing, and a circuit is getting cooked, which caused it to shutdown today due to overheating. But if that were true, it should have powered back up after I let it cool down to ambient. I could not get it to do anything until I removed power and slowly cycled the power button ~10 times. So maybe a thermal shutdown caused by a failing component, and a really dirty power switch?
Of note is that I updated the router firmware to v3.0.0.4.382.51939 about a week ago. The update went fine and I don't know if it's related in any way. Also, in my digging today I found some posts talking about how hot some Asus routers get, and how its best to orient them vertically. Having looked inside and seen where the heatsinks are, I think orienting it horizontally (i.e. sitting on a table) would be best, which is the way it has been sitting for years. I spent half the day dealing with swapping in another (Netgear R7800) that I was using as a access point, and dealing with a less than cooperative cable modem. I don't want to swap the RT-AC87U back in and reset the Netgear as an AP again if the Asus router is going to fail. While typing this I just put my hand on heat sink SH1 and its really hot. SH2 and SH3 jest get warm. Any ideas or suggestions?
