RT-AX88 with the latest FW and these weird log messages
Logi
Ethernet port #7 is empty, it was being used like 2 hours ago, but moved the cable to port #2, also the MAC 44:61:32:A9:0F:93 is not any of the current devices connected to it, these messages are non stop, anyway to fix it? Thanks
Feb 6 10:08:42 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-52
Feb 6 10:08:43 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Previous authentication no longer valid (2), rssi:-52
Feb 6 10:09:10 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-52
Feb 6 10:09:11 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Previous authentication no longer valid (2), rssi:-52
Feb 6 10:09:21 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-52
Feb 6 10:09:22 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Previous authentication no longer valid (2), rssi:-52
Feb 6 10:09:43 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-52
Feb 6 10:09:43 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Previous authentication no longer valid (2), rssi:-52
Feb 6 10:10:10 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-53
Feb 6 10:10:11 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Previous authentication no longer valid (2), rssi:-53
Feb 6 10:10:21 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-53
Feb 6 10:10:22 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 44:61:32:A9:0F:93, status: 0, reason: Previous authentication no longer valid (2), rssi:-53
This MAC address is perhaps ecobee device. eth7 is not Ethernet port #7.
Posting at the same time with Colin... Also try disabling DoT if you have it enabled and try again.
