RT-AX88U - DHCP limit is it 64 or 128 devices?
BlueiPhone
I am confused. I am running on a RT-AX88U and with firmware 384.18. I manage all my devices on my local network using DHCP on the RT-AX88U. I was adding my grandson’s laptop to the DHCP table and this message popped up. I thought I could have 128 devices in the table.
I do have 64 devices in the table and get this message when I try to add the 65th device.
I uploaded firmware 384.19 to the router and same message.
What am I doing wrong?
figorr
I also thought that you can manual assign 128 devices, and not only the 50%.
I only have 54 devices under my rt-ax88u. I have not reached this limit yet.
Jack Yaz
Part of the Furniture
figorr
Ok. Thank you Dave.
I am always using the DHCP Server tab under the LAN settings when I want to add a new manual assignment. ☺️
JGrana
All the more reason to not use the WebUI/nvram for assigning static addresses and using a dnsmasq.conf.add file.
No more limits to number of entries or (as of the 384 code base) number of characters.
@Xentrk created a script that makes it easier to convert the first time.
This assumes you are comfortable using the CLI and an editor like nano or vi.
Yo_2T
At that number of devices, what's the point with manually assigning the DHCP lease? Just let the DHCP server do its thing...
