QoS not showing any activity AX88U
Sptz
Hi all,
Using the latest Merlin on an AX88U. I've noticed that in the QoS window, it doesn't show any internet activity, all gauges at 0. in the main dashboard it does show activity but I can't see which device is the cause.
This was working on the vanilla firmware. Any ideas?
Thanks!
You mean Data Classification or Bandwidth Monitor - both need the BWDPI Engine (Trend Micro), if it's off and you go to Data Classification, you should see "
Note: Statistics require Traditional QoS mode or the TrendMicro bwdpi engine to be enabled.". BWDPI start up on reboot and runs for a bit unless you go through the effort of turning features off, it stays on.
Try turning on (then off if you don't need it) QoS, App Analysis, Web filters, Time Schedueling, etc that will start the engine. If everything is off, and you hit apply twice at the bottom of the Data Classification page BWDPI turns off.
I also remeber in a prior release there wer problems with it but as you say you are on the latest (388.6)
I forgot to specify it's in the Bandwidth Monitor section yes:
Yes everything is off as I have no need for anything QOS / historical data related
