RT-AX92U Node does not connect when DWB settings are changed
  • ATTENTION! As of November 1, 2020, you will not be able to reply to threads 6 months after the thread is opened. Threads will not be locked, so posts may still be edited by their authors.
RouterRat
I got 2 of above devices and want to use them in a mesh setup. Installation was easy, node and router found eachother, however with Auto settings only 80mhz are used, even if I select 160mhz as only Option in the router. If I select channels manually, the Log says that 160mhz are used, but then the node does not connect on the 2nd 5ghz band anymore. It looks Like the settings from the router are not taken over by the node. Ist that expected behaviour and how can i configure a 160mhz Mesh setup?
Th
