unknownbeef
[SOLVED]
router: ac66u
firmware: 376.49_5
two options are "stuck" on in the web interace on my router:
enable dlna media server: on
samba enable share: on
i can't change the buttons to the off state. i click them and nothing happens.
can i disable the two options from ssh by changing the nvram variables directly? does anybody know the variable names and what i need to type at the terminal to accomplish this?
thank you so much in advance!
EDIT: (Solution)
I couldn't find the solution through Google, but I was able to use grep and nvram show to search out the necessary variables. In case anybody else runs in to a similar issue, here is how I fixed this:
at the ssh prompt:
nvram set enable_samba=0
nvram set dms_enable=0
nvram commit
reboot
I hope this helps somebody out there. Cheers!
router: ac66u
firmware: 376.49_5
EDIT: (Solution)
at the ssh prompt:
nvram commit
reboot
