Uninstall entware
L&LD
Part of the Furniture
could someone give me an advice how i could uninstall entware?
Greetings from Germany
If that is the only goal: format the drive. :)
If you have more details to share, we can do the same. ;)
dave14305
If you no longer use Diversion or Pixelserv, you can manually edit these files to remove the entware startup code, but be sure you really don’t need entware anymore.
  • /jffs/scripts/services-start
  • /jffs/scripts/services-stop
  • /jffs/scripts/post-mount
thelonelycoder
Hi, is there no more elegant way?
Is Diversion installed? Use the Uninstall function in d. Since Diversion likely installed Entware it can also remove it.
If not and no other scripts are used, just format the jffs. There's an option to do so in the WebUI in Administration/System.
After rebooting Entware will no longer be loaded and you can remove the "entware" folder on your attached USB device.
elgreco29
Ok, got it. That means for me, that entware and my fire tv sticks have difficulties. In my special way, with entware installed, bubbleupnp can't see the sticks as a renderer. Without entware, all works fine.
RMerlin
Asuswrt-Merlin dev
All Entware is is a software repo. Entware in itself has no impact on your LAN, what you install through it does.
