1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
USB printing issues using router as print server.
Discussion in 'ASUS Wireless' started by xrayed, Jan 2, 2018.
  1. xrayed
    xrayed New Around Here
    Jan 1, 2018
    5
    I have an HP 1320 connected to my AC68U router via USB cable. I did the proper setup and it works as a network printer. I have to reboot the router every other day to "refresh" the connection as the printer will stop working and jobs will just hang in the queue. Is there something I am missing that is causing this timeout or is it just the nature of the beast? Once rebooted all waiting jobs will print. Does not matter if I send from my laptop wirelessly or my wired desktop.
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. xrayed
    Jan 1, 2018
    5
    Wow, 70 reads and no one has a comment? am I the only one using this option or the only one with the problem????
  4. Klueless
    Klueless Senior Member
    Jan 1, 2016
    432
    Rochester, NY
  5. xrayed
    Jan 1, 2018
    5
    That is a very small list, wow ASUS really killed that feature. Mine works although not on supported list but it just does not keep a sustained connection. A reboot refreshes the connection like the USB goes to into power save mode or something like that. So compatibility wise I think its fine, my guess is there should be a setting on USB port to disable time out or sleep mode....
  6. Klueless
    Jan 1, 2016
    432
    Rochester, NY
    Yes. But they did say those are just the ones they tested with. Seems like old info, perhaps because many printers come with built-in networking. I've never used it but it looks like they have two printer widgets, asus and lpr. Which are you using?
    I run a usb "disk" on my asus with no "sleeping" problems. Perhaps it's the printer going to sleep and not the usb port? What happens if you simply "power" the printer (or something) before printing?
    I assume you've already tried both USB ports and/or you're using usb 2 rather than 3?
    Good luck. It's frustrating when things "almost" work ...
  7. xrayed
    Jan 1, 2018
    5
    Thanks Klueless, I am using port 2 as I have an aux HDD on port 3 using the USB 3.0 capability. The printer does not sleep as ready lite is always on. This is a pre energy saver one . LOL So power cycling the printer does not change the problem.
    Wait, found something I can try, I have been using a conversion cable that converts standard printer output to usb, I just realized it does have a usb output. I will switch cables and see it it makes a difference. Don't know why I went that route in the first place other than I did not look at the back very good .
  8. Klueless
    Jan 1, 2016
    432
    Rochester, NY
    Any luck?
  9. xrayed
    Jan 1, 2018
    5
    Ok switched cables and had to reload printer. Strange thing was I could not print test sheet at first but the printer randomly printed out a a blank sheet with smiley faces going across the top of page about 1/2 inch down. Did this about 3 times without a print request????After the third attempt i got it working. We will see how it performs in the long run.
    Update: It seems to be working better. So far print requests are working or t least triggering a response from the printer. Still get an error sometimes but then its prints the job anyway. kind of like a memory buffer overrun ???
  10. Klueless
    Jan 1, 2016
    432
    Rochester, NY
    Thanks for the update. So ... not quite happy but not grumpy either? There's another thread out talking about printer problems, maybe you'll find something useful in it?
