Hi everybody.
While setting up AX86U-AX88U site-to-site connection using WigeGuard I have the following problem with the VPNDirector configuration on server side:
Some subset of IP on the wireguard server router (say 172.16.22.50-100) should send all their traffic through wg vpn to client side router (say 192.168.100.1) and after that to its wan (ISP link).
If the goal is opposite (from client router to server router) - no troubles, I just chose in GUI WGC<X>.
But there is no option to choose WGS[server]<X>
Now I've built two tunnels AX86U=>AX88U and reverse AX88U=>AX86U, but it seems like a bit messy solution.
Does anyone have any idea how to implement this?
Or probably better to ask to extend the VPNDirector popup list?
