przemekwawa
Is it possible to use in RT-AX88U Pro two 2,5gbit ports as LAN? Normal, without Pro had no 2,5 but I see that Pro has one described as WAN, second as LAN.
If it is not, what would you reccomend as router with two 2,5 lan? AXE16000 is pretty expensive...
I have currently RT-AX86U + RT-AX86S as mesh connected by wifi, but I am thinking about new router and use 86U as mesh (with migration to ethernet connection).
Another connection, would aimesh work with cable connection but with switch between them (not managed)? Theoretically yes but...
