3.0.0.4.188 for Asus RT-AC66u is Out
Keynote
Asus has posted 3.0.0.4.188 firmware for the Asus Rt-AC66u. Anyone installed it yet and can tell me what the optimal settings are to get the most power out of the TX controls? It looks like Asus implemented them slightly differently. Any first impressions of the new firmware?
ASUS RT-AC66U Firmware Version 3.0.0.4.188
Fixed
1. Comcast IPv6 related issues.
2. UPnP media server restart issue
3. Wireless radio schedule setting issue
4. Stabilize media bridge wireless trasmission.
5. Network map client list related issue.
Modify
1. Enable Tx power adjustment.
2. Update 3G/4G modem profiles
3. Allow Upnp port redirect external port: 1-65535 to internal port 1024-65535
4. QoS user interface, shows applied rule in first page.
Add
1. Support Huawei K3770 USB Modem
2. NO-IP support
http://support.asus.com/Download.aspx?SLanguage=en&m=RT-AC66U&p=11&s=2
Binary only, source code hasn't been released for the new build.
Does anybody know what new wireless driver version Asus introduced?
Use command "wl ver" through telnet/ssh
Well, this firmware version doesn't cause tons of wireless download problems when QoS is enabled, at least. So, I'll be sticking with this firmware for now.
I'm not using a UPnP server with Broadcast support enabled in VPN, so I can't comment on that issue.
Under TX Power, it now states:
"FCC channel 34~48 max: 50mW for North America.
FCC channel 149~165 max: 1000mW for North America.
ETSI max: 200mW for Europe, South America and APAC.
The real Tx power is automatically adjusted due to regional regulatory. "
5GHz Transmit Radio Power adjustments do appear to work as expected with this firmware.
I Have FW188 and I still get constant crashes. Xbox live speeds are very poor too. Cant stream video. Not sure what my next step should be.
I Have FW188 and I still get constant crashes. Not sure what my next step should be.
Have you tried Asuswrt-merlin? I have implemented a few stability-related fixes, try the latest beta build (178.16), it includes an additional stability fix that wasn't in 178.15.
The 178.16 is great!! I have tried with no serious problem detected so far.
Will the driver be updated in next ASUSWRT-MERLIN fw? I noticed that the driver in official FW 188 for AC66U have been updated.
6.30 RC39.31
wl0: Aug 29 2012 12:34:30 version 6.30.39.31 (r341183)
6.30 RC39.31
Yes, I always use whatever driver Asus uses with the firmware version I base my code on.
