Typical max with 300Mb/s dual-chain N will be 130-150Mb/s reported, 100Mb/s or so transfer rate real-world. If you're close to that with whatever gear you have, you're likely not going to do much better with a 2x2 station and client on 2.4Ghz, regardless the hardware/software running the show.What's the fastest speed you've gotten with 2.4ghz. I can never get over 100mbp if standing next to ap
Nah, of course not. There has to be somebody out there whose done this with iPhones/iPads. I just happen to fall into the Android camp. As far as Ruckus maximum associated clients and active connections goes, here's the current product guide for their APs:I notice nobody ever claims roaming with an iPhone. It is always with an Android. It is hard to believe all network guys use Androids. I would also think the density would be higher on the commercial wireless over the consumer level gear. How many connections and active connections does the Ruckus support?
They do list a max of 64 per radio on the 500 series APs. I would think for much more than 100 or so active clients routinely you'd need an Aironet-based solution if you wanted to stay with Cisco.I think you get 200 connections and 128 active users per AP in the Cisco small business world.
A marketing term, usually, but with Ruckus it actually signifies which APs will accept one of their IoT modules, which allow for BLE, Zigbee and LoRa connectivity for IoT endpoints that don't have onboard wifi.What does "IoT ready" mean? Is it just marketing crap. What difference does it make whether you run across wireless of not?
Welcome To SNBForums
