I currently have the GT=AC5300 as the primary router and a AC86U as a mesh node. I noticed that the 2.4 Ghz band on the 86U has been off and on recently (and i have read the post regarding this issue). There was some suggestions on trying to stabilize the 2.4Ghz in settings, so in order to try those out, i need to get into the firmware settings of the 86U, but everytime i type in the IP that the GT-5300 assigned the 86U it defaults to the login of the 5300. My question is, if i make changes to the 2.4 Ghz settings in the 5300, are they updated in the 86U settings....im leaning to No, but i dont know that much about how the mesh handles a nodes configuration if the main router config changes
thanks
Kevin
thanks
Kevin
