I flashed Merlin Tonite on my router. I did make sure it was the correct version, well reviewed etc... The update went well the I manually reset the router as per the instructions. It then began to only blink the power light and the web activity light on and off . When I try to plug in Ethernet cable directly it just shows no connection. None of the WiFi signals are showing. I tried to do the factory reset by holding the wfs button for ten seconds and then unplug the power and plug it back in afterwards and the same activity of only those two lights remains. Any thoughts on what I'm missing or where I went wrong? Thanks for the help
