I read in one of the posts that ASUS TUF-AX5400 is used as main node and ASUS RT-AX92U as AIMesh node.
I want to know as to which one is a more powerful router in terms of CPU, Memory etc. and with better functionality of the two above (not concerned with gaming related features though).
Currently I am using two ASUS RT-AX92U in AIMesh mode with one as main router and one as AIMesh node and using some old routers which are not from ASUS as access points (not available in AIMesh). I am thinking of replacing one of the old router used as access point with an ASUS AIMesh compatible router and in case I do that, I know which one should I purchase.
Any other suggestion is also welcome.
