dave14305
Part of the Furniture
I have the same RT-AX88U Pro with 102.5 running and don't see such issues. Do you have any uncommon addons installed, or anything that might be trying to modify the UI pages? Do you see any bind mounts if you run theYes, WAN access is enabled, password has been modified to the new requirements, and both Firefox & Chrome cache (everything) have been cleared (all time) -- also used private mode in both. The problem still remains. I'll check the underlying code to see how it's being triggered.
mount command on the router? Something would need to be messing with your EN.dict file for this to break so oddly.
# md5sum /www/EN.dict
d10200dcafaa2f5150928563f655f97a /www/EN.dict
# nvram get buildno
102.5
# grep -E "\"(wireless_tab|status_tab)\"" /www/device-map/router_status.asp
# sed -n '513p' /www/EN.dict
Wireless
