AX3000 on 386.7 and google services connectivity issues/strange behavior.
lepa71
Hi all
I have a Verizon ARC-XCI55AX running in passthrough mode. It connects to my AX3000. I upgraded to 386.7 last week and I seem to have strange behavior. Access to gmail, youtube or even trying to go to google.com times out. I can access other sites ok. Some of them would take longer to load and some are just fine. To rule out the router, I connected to Verizon cube with wire and I can connect to everything just fine, connecting back and still have problems. I would get everything beck to normal if I reboot AX3000.
Is there something I can try to figure out that is causing it?
I looked at the logs and I don't see anything wrong there. There is no pattern I can see.
Any thoughts before I go back to either stock or previous merlin fw?
L&LD
Part of the Furniture
Is the same behavior present with RMerlin 386.7.1?
lepa71
386.7_1 did not help. This is what logs are showing.
Jul 13 17:07:26 wlceventd: wlceventd_proc_event(505): eth6: Auth C6:A9:E1:9D:74:77, status: Successful (0)
Jul 13 17:07:26 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind C6:A9:E1:9D:74:77, status: 0, reason: Previous authentication no longer valid (2)
Jul 13 17:07:26 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind C6:A9:E1:9D:74:77, status: 0, reason: Unspecified reason (1)
Jul 13 17:07:26 wlceventd: wlceventd_proc_event(534): eth6: Assoc C6:A9:E1:9D:74:77, status: Successful (0)
Jul 13 17:08:13 rc_service: cfg_server 2556:notify_rc restart_wireless;restart_firewall;
Jul 13 17:08:13 kernel: Flushing net_device wl0.1.
Jul 13 17:08:14 kernel: CSIMON:  CSIMON[1.1.0] Initialization
Jul 13 17:08:14 kernel: CSIMON: M2M usr already registered ...
Jul 13 17:08:15 kernel: CSIMON:  CSIMON[1.1.0] Initialization
Jul 13 17:08:15 kernel: CSIMON: M2M usr already registered ...
Jul 13 17:08:15 wlceventd: wlceventd Start...
Jul 13 17:08:18 wlceventd: wlceventd_proc_event(505): eth5: Auth 84:72:07:71:F3:CD, status: Successful (0)
Jul 13 17:08:18 wlceventd: wlceventd_proc_event(534): eth5: Assoc 84:72:07:71:F3:CD, status: Successful (0)
Jul 13 17:08:21 wlceventd: wlceventd_proc_event(534): eth5: Assoc FE:F9:9E:7E:AC:CC, status: Successful (0)
Jul 13 17:08:21 wlceventd: wlceventd_proc_event(469): eth5: Deauth_ind 84:72:07:71:F3:CD, status: 0, reason: Unspecified reason (1)
Jul 13 17:08:21 wlceventd: wlceventd_proc_event(505): eth5: Auth 84:72:07:71:F3:CD, status: Successful (0)
Jul 13 17:08:21 wlceventd: wlceventd_proc_event(534): eth5: Assoc 84:72:07:71:F3:CD, status: Successful (0)
Jul 13 17:08:25 roamast: ROAMING Start...
Jul 13 17:09:16 wlceventd: wlceventd_proc_event(505): eth6: Auth 00:28:F8:94:7F:E6, status: Successful (0)
Jul 13 17:09:16 wlceventd: wlceventd_proc_event(534): eth6: Assoc 00:28:F8:94:7F:E6, status: Successful (0)
Jul 13 17:09:18 wlceventd: wlceventd_proc_event(505): eth6: Auth F0:EF:86:F7:C6:BB, status: Successful (0)
Jul 13 17:09:18 wlceventd: wlceventd_proc_event(534): eth6: Assoc F0:EF:86:F7:C6:BB, status: Successful (0)
Jul 13 17:09:26 wlceventd: wlceventd_proc_event(486): eth5: Disassoc FE:F9:9E:7E:AC:CC, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jul 13 17:09:49 wlceventd: wlceventd_proc_event(505): wl0.1: Auth 84:72:07:71:EA:B0, status: Successful (0)
Jul 13 17:09:49 wlceventd: wlceventd_proc_event(469): wl0.1: Deauth_ind 84:72:07:71:EA:B0, status: 0, reason: Unspecified reason (1)
Jul 13 17:09:49 wlceventd: wlceventd_proc_event(534): wl0.1: Assoc 84:72:07:71:EA:B0, status: Successful (0)
Jul 13 17:09:50 wlceventd: wlceventd_proc_event(534): eth5: Assoc FE:F9:9E:7E:AC:CC, status: Successful (0)
Jul 13 17:09:54 wlceventd: wlceventd_proc_event(469): wl0.1: Deauth_ind 84:72:07:71:EA:B0, status: 0, reason: Previous authentication no longer valid (2)
Jul 13 17:09:54 wlceventd: wlceventd_proc_event(505): wl0.1: Auth 84:72:07:71:EA:B0, status: Successful (0)
Jul 13 17:09:54 wlceventd: wlceventd_proc_event(469): wl0.1: Deauth_ind 84:72:07:71:EA:B0, status: 0, reason: Unspecified reason (1)
Jul 13 17:09:54 wlceventd: wlceventd_proc_event(534): wl0.1: Assoc 84:72:07:71:EA:B0, status: Successful (0)
Jul 13 17:09:54 wlceventd: wlceventd_proc_event(505): eth6: Auth 5A:CA:92:9F:A8:E8, status: Successful (0)
Jul 13 17:09:54 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind 5A:CA:92:9F:A8:E8, status: 0, reason: Previous authentication no longer valid (2)
Jul 13 17:09:55 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind 5A:CA:92:9F:A8:E8, status: 0, reason: Unspecified reason (1)
Jul 13 17:09:55 wlceventd: wlceventd_proc_event(534): eth6: Assoc 5A:CA:92:9F:A8:E8, status: Successful (0)
Jul 13 17:10:18 wlceventd: wlceventd_proc_event(505): eth6: Auth 44:78:3E:BA:EC:C7, status: Successful (0)
Jul 13 17:10:18 wlceventd: wlceventd_proc_event(534): eth6: Assoc 44:78:3E:BA:EC:C7, status: Successful (0)
Jul 13 17:10:54 wlceventd: wlceventd_proc_event(505): eth6: Auth BE:74:7A:94:6B:82, status: Successful (0)
Jul 13 17:10:54 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind BE:74:7A:94:6B:82, status: 0, reason: Previous authentication no longer valid (2)
Jul 13 17:10:55 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind BE:74:7A:94:6B:82, status: 0, reason: Unspecified reason (1)
Jul 13 17:10:55 wlceventd: wlceventd_proc_event(534): eth6: Assoc BE:74:7A:94:6B:82, status: Successful (0)
Jul 13 17:10:55 wlceventd: wlceventd_proc_event(505): eth6: Auth C6:A9:E1:9D:74:77, status: Successful (0)
Jul 13 17:10:55 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind C6:A9:E1:9D:74:77, status: 0, reason: Previous authentication no longer valid (2)
Jul 13 17:10:55 wlceventd: wlceventd_proc_event(534): eth6: Assoc C6:A9:E1:9D:74:77, status: Successful (0)
Jul 13 17:11:02 wlceventd: wlceventd_proc_event(469): wl0.1: Deauth_ind 84:72:07:71:EA:B0, status: 0, reason: Unspecified reason (1)
Jul 13 17:11:02 wlceventd: wlceventd_proc_event(505): wl0.1: Auth 84:72:07:71:EA:B0, status: Successful (0)
Jul 13 17:11:02 wlceventd: wlceventd_proc_event(534): wl0.1: Assoc 84:72:07:71:EA:B0, status: Successful (0)
Jul 13 17:11:05 wlceventd: wlceventd_proc_event(469): wl0.1: Deauth_ind 84:72:07:71:EA:B0, status: 0, reason: Unspecified reason (1)
Jul 13 17:11:05 wlceventd: wlceventd_proc_event(505): wl0.1: Auth 84:72:07:71:EA:B0, status: Successful (0)
Jul 13 17:11:05 wlceventd: wlceventd_proc_event(534): wl0.1: Assoc 84:72:07:71:EA:B0, status: Successful (0)
Jul 13 17:25:28 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind 44:78:3E:BA:EC:C7, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Jul 13 17:41:50 wlceventd: wlceventd_proc_event(505): eth6: Auth 44:78:3E:BA:EC:C7, status: Successful (0)
Jul 13 17:41:50 wlceventd: wlceventd_proc_event(534): eth6: Assoc 44:78:3E:BA:EC:C7, status: Successful (0)
