Cannot login after downgrade
RobbieBlok
Just upgraded my AC86U to Merlin 384.19 .
The upgrade went fine, but my VPN Client could not startup.
I Thought the easiest way would be to just quickly put back the previous firmware 384.9 and check if that was working.
Now unfortunately I cannot login to the router anymore.
The router itself seems to be working, I can connect to Wifi, and also the VPN Client seems to work again.
I could do a factory reset, but would rather avoid that.
The standard pass admin admin also does not work.
What could this be?
Rob
Jack Yaz
Part of the Furniture
What could this be?
Rob
Latest Asus code in 384.19 encrypts passwords, so reverting requires a factory reset as older versions cannot use the encrypted password
L&LD
Moving up 10 firmware versions would do that.
I suggest doing an M&M Config and ideally, also a Nuclear Reset to get your router and network back to a good/known state. Please see the last two paragraphs in the link below.
RobbieBlok
Aha, that could make sense.
Is there another way to reinstall the latest firmware, without login in the user interface? Maybe telnet?
Do you know why the VPN Client stopped working with the latest firmware?
Rob
RMerlin
Asuswrt-Merlin dev
Put the router into firmware recovery mode, and use Asus's Firmware Recovery Tool.
As for your VPN problem, the system log would tell you why it's failing.
RMerlin
Asuswrt-Merlin dev
RobbieBlok
I was able to restore the latest firmware again, and I can logon to my router again. :)
However, the OpenVPN client now gives me the same problems:
Sep 6 19:05:39 kernel: klogd started: BusyBox v1.25.1 (2020-08-14 15:19:48 EDT)
Sep 6 19:05:57 ovpn-client1[5834]: Options error: You must define CA file (--ca) or CA path (--capath)
Sep 6 19:05:57 ovpn-client1[5834]: Use --help for more information.
Sep 6 19:06:46 ovpn-client1[6120]: Options error: You must define CA file (--ca) or CA path (--capath)
Sep 6 19:06:46 ovpn-client1[6120]: Use --help for more information.
I cant remember that I did something to the CA file on the previous firmware, so it must be something to do with the latest firmware.
Any hints?
RMerlin
Asuswrt-Merlin dev
RobbieBlok
Thats what I did a few times.
Not working.
In the old config I only needed to import the config file btw. And fill in my username and password.
RMerlin
Asuswrt-Merlin dev
Not working.
Please post your config file.
RMerlin
Asuswrt-Merlin dev
The CA seems to be properly inlined, so importing the config should populate the CA certificate field automatically. Have you followed the JFFS reset instructions listed in the 384.19 changelog that are specific to the RT-AC86U? Certificates get stored in the JFFS partition, so if it's corrupted, storing it will fail.
RobbieBlok
Yesss,
That did it.
Formatted the RFFS partition, and reloaded the settings.
Your the best Merlin, thanks.
Rob
