rikd
As oe of you saw in previous thread am trying to setup my home LAN with a DGL-4500 doing 5GHz11N, and a DIR-655 doing 11G.
the DGL is the router providing internet (via DSL modem), DHCP and QoS.
My problem is trying to get the 2 routers connected so that the devices hooked off the DIR can access the internet.
I've looked at quite a few guides but am struggling to get it working..
I have the DGL with the output from the modem connected to the it's WAN port. IP is set to 192.168.0.201/255.255.255.0, DHCP set to range 192.168.0.100-192.168.0.199
I then configured the DIR to have an IP of 192.168.0.202/255.255.255.0 with DHCP, FW, QoS all turned off. Then configure (as suggested by other sites) the internet settings to static IP where
IP is 192.168.0.202
Subnet 255.255.0.0
GW 192.168.0.201
But the DIR refuses to allow it complaining that the WAN and LAN subets are conflicting.
Anybody got any ideas?
IP is 192.168.0.202
Subnet 255.255.0.0
GW 192.168.0.201
