Diversion Help - need help with Diversion and Whatsapp & Signal issues please
NotA+
Hello
I hope you might be able to help.
I have the AC86u.
Merlin FM ( thank you Merlin :) )
Also, using Skynet.
WA is connecting and disconnecting frequently.
(I am using the standard list & have whitelisted known the main WA domains.)
Signal connection is fine but sending media (image etc) does not work.
It was working fine prior to this.
I have whitelisted the known signal domains.
I don't believe it would be Skynet as that is a FW?
So, Diversion? What am I doing wrong?
Any ideas gratefully received.
Thanks.
NotA+
Whatsapp:
Whatsapp.com
Whatsapp.net
Wa.me
Signal:
Allow *.whispersystems.org, *.signal.org, TCP port 443, and UDP traffic. If you have a transparent or reverse proxy it needs to support WebSockets. Signal uses a non-standard TCP port to catch filtering issues at the signaling step and also utilizes a random UDP port. All UDP ports will need to be opened. The underlying IPs are constantly changing, so it'd be hard to define accurate firewall rules.
Thank you.
Tech9
Part of the Furniture
Disable Diversion - test. Disable Skynet - test again. It may point you to which one is blocking something you need.
Galgofa
Same issue here. Disabled all and then tested one by one (only skynet, only unbound, only diversion installed), result is Diversion somehow block WA to work properly. Any suggestion though ?
Amwjujo
Maybe this can help you:
Galgofa
Thank you. But i believe the issue with Google Push services, i also cant receive messages on WA after a while it is closed on the phone. Research with uiDivstatus doesn't help a lot to discover. Incoming messages are failed to appear until apps opened on the phone. Web application saying no internet connection with phone...
Galgofa
Just follow your quoted post and found frequently blocked domain: app-measurement.com
reading the net found this domain is responsible for push services. whitelisted and deleted from blacklist. will see.
