Help please! AC68U Dual WAN. Routing specific IPS to different gateway.
Bishi
I did a search but can't find any with a similar issue.
I am currently using the latest Merlin 376.48_1 build on my AC68U.
I have two slow (8mb) ADSL connections in WAN / Ethernet 1 ports.
What I want to do is route all of the traffic from my primary pc to one of the adsl routers and all the traffic from every other device in the house to the other (server pc, phones etc).
Here are my dual wan settings
http://s18.postimg.org/4853j3yi1/dualwan.png
As you can see only one IP is assigned to the primary wan. All computers have a reserved DHCP address.
What I am finding is that whilst running a ping from my primary pc - if I start a download on another computer, for instance a torrent download on my server I still experience latency although it does seem to cap the bandwidth the server (from looking at the download speed) is using to half the normal dual wan amount with no routing enabled.
What's going on here? Have I done something wrong and is there a better way to facilitate this?
Thanks in advance
