A bit annoyed that I discovered my pro pioneer doesn't support vlan tag or whatever. I thought that's what the 2nd NIC was for!
Anyways, I don't have any segregated networks or anything. I thought jumbo frames and vlan tags were the answer for me, but unrealized limitations thwarted that.
I have a 2008 R2 server machine hooked up to a GS108t. I'm using it for Hyper-V.
My virtual disks are on my pro pioneer with x-raid2. The two are right next to each other on the GS108t. Without hyperV turned on, I get about 50MB/s transfer (measured by windows 2008r2) from my pro pioneer to my 2008 Server R2 machine.
Simple question is, shouldn't I be doing better? Would jumbo frames actually work (or screw up the rest of my network? I have a cable hooking up the switch to a WNDR3700)
I see on the charts that a readynas pro 6350 hits 104.7.... how can I get these numbers?
