How can I limit a clients total internet time per day on the router without using scheduling? For example, 4 hours to use whenever they want.
Daxx123
I have an RT-AC86U running with 386.7-2 Merlin. How can I go about limiting a client's total time usage per 24 hour period? I would like a client to have 4 hours of usage per day but not tied to any time schedule, free to use 4 hours whenever, and turns off when they go over the limit. I don't see this option in Asuswrt-Merlin, but can it be done?
dave14305
Part of the Furniture
I don’t think there’s any inherent way for a router to manage a time budget. There are byte quotas or fixed time windows via iptables, but it isn’t practical for the router to track a client‘s elapsed wall clock time spent online. Would the router only count time spent sending or receiving packets to that client? It may take 5 seconds to download a big webpage, but take 30 minutes to read. Does that count as 5 seconds or 30 minutes?
The task is better suited to some parental control software residing on the client, if that’s the type of scenario you’re after.
Daxx123
Here is how a different router brand handles what I'm trying to accomplish. It seems possible, just not sure how on the Asus since it's not built into the GUI.
MissingTwins
I have a suggestion.
This can be done with a shell script and crontab.
Assuming 192.168.9.1 is the router IP, 192.168.9.100 is the device IP.
1. Make DHCP binding to the MAC address.
echo "192.168.9.100/32,60" >> /tmp/timer_list.txt
2. Use iptables to monitor the either INPUT or OUTPUT packet counts(activity) of target device(ip)
Bash:
# count down
iptables -nvL -Z INPUT | grep 192.168.9.100/32 | grep -iPo '^\s*\d+[KM]?'
if [ "$?" -ne 0 ];then
   awk -F',' '{printf("%s\t%d\n",$1,$2-1)}' /tmp/timer_list.txt
fi
# remove time-up nodes
sed -ir '/.+?,0/d' /tmp/timer_list.txt
# add/remove barrier to the nodes
grep '192.168.9.100/32' /tmp/timer_list.txt
    iptables -t nat -A PREROUTING -s 192.168.9.100/32 -p tcp -m multiport --dport http,https -j DNAT --to-destination 192.168.9.1:4444
else
    iptables -t nat -D PREROUTING -s 192.168.9.100/32 -p tcp -m multiport --dport http,https -j DNAT --to-destination 192.168.9.1:4444
else
fi
3. Sampling every minutes, if packet counts increased, subtracting 1-minute
*/1 * * * * /jffs/scripts/activity.sh
4. If remaining minutes equals to 0, replace iptables target IP with `reject-with icmp-host-prohibited`
sudo iptables -I INPUT -s 192.168.9.100/32 -j REJECT --reject-with icmp-host-prohibited
or even better you may intercept the HTTP requests to your pre-defined http web hosted by local socat based on poor man's http server, and warn the time-upped user.
Interception
sudo iptables -t nat -A PREROUTING -s 192.168.9.100/32 -p tcp -m multiport --dport http,https -j DNAT --to-destination 192.168.9.1:4444
Poor man's HTTP server
socat -d TCP4-LISTEN:9444,reuseaddr,fork,crlf SYSTEM:./httpd.sh,pipes
Bash:
#!/bin/bash
# socat -d TCP4-LISTEN:4444,reuseaddr,fork,crlf SYSTEM:./httpd.sh,pipes
# curl http://127.0.0.1:4444
is_debug=0
tmp=$(mktemp -td)
function finish() {
    printf -- '-%.0s' {1..20}  1>&2
    echo ""  1>&2
    rm -rf "$tmp"
trap finish EXIT
echoerr() { echo "[email protected]" 1>&2; }
echoheader() {
    headers="[email protected]\n"
echobody() {
    txtBody="[email protected]\n"
    [ "$is_debug" -gt 0 ] && echo "[email protected]" 1>&2;
endheader() {
    RESPONSE_CODE="$1"
    echo "$RESPONSE_CODE" 1>&2;
    CONTEN_TYPE="$2"
    if [ -z "$CONTEN_TYPE" ];then
        CONTEN_TYPE="text/html; charset=utf-8"
    fi
    printf "HTTP/1.0 $RESPONSE_CODE\n"
    printf "Cache-Control: no-store,no-cache\n"
    printf "Content-Type: $CONTEN_TYPE\n"
    byteCNT=$(echo -en "$txtBody" | wc -c)
    LineCNT=$(echo -en "$txtBody" | wc -l)
    totalCNT=`expr $byteCNT + $LineCNT`
    printf "Content-Length: $totalCNT\n"
    printf "$headers\n"
    txtBody="${txtBody//%/%%}"
    printf "$txtBody\n"
    d=`date '+%m-%d %T'`
    echoerr "[ ] $RESPONSE_CODE $LineCNT lines $byteCNT|$totalCNT bytes | $HTTP_DEBUG"
    echoerr ""
    echoerr ""
    sleep 0.1
    exit 0;
read -r -d '' html_body <<- EOM
    <html>
    <Body>
    [info_msg]
    </Body></html>
EOM
D_SPACE="Time is up!"
html_body=${html_body//\[info_msg\]/$D_SPACE}
echobody "$html_body"
endheader "200 OK"
Tech9
This looks like TP-Link GUI, but may I ask what model has this feature included?
MissingTwins
Nice script. How can the iptables entry be disabled / removed again to enable access?
The -D will do.
Bash:
iptables -D INPUT -s 192.168.9.100/32 -j REJECT --reject-with icmp-host-prohibited
Or you may prefer to ipset, then you can keep the iptables unchanged, just add/remove items in ipset.
Bash:
ipset -exist create clients_ipv4 hash:net counters
ipset -exist add clients_ipv4 192.168.9.100/32
iptables -I INPUT -i ${ip4if} -m set --match-set clients_ipv4 src -j ACCEPT
iptables -A INPUT -i ${ip4if} -j REJECT --reject-with icmp-host-prohibited"
ipset -exist create clients_ipv6 hash:net counters family inet6
ipset -exist add clients_ipv6 fec0::100/128
ip6tables -I INPUT -i ${ip6if} -m set --match-set clients_ipv6 src -j ACCEPT
ip6tables -A INPUT -i ${ip6if} -j REJECT --reject-with icmp6-adm-prohibited
Remove IPs
Bash:
ipset -exist del clients_ipv4 192.168.9.100/32
ipset -exist del clients_ipv6 fec0::100/128
