1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
How do I downgrade AC5300 to 380.59
Discussion in 'Asuswrt-Merlin' started by ASadani, Sep 14, 2018.
  1. ASadani
    ASadani Regular Contributor
    Apr 27, 2017
    151
    Hi All, I want to downgrade to 380.59, however, when I do that through recovery, the router gets messed up. The CPU Spikes constantly with CPU1 and CPU2. The pppoe connection stops working and the Telnet does not get enabled. The only way to fix this is to upgrade it back to 380.70+.
    Is there a downgrade base firmware of stock or merlin that I can try to get me back to 380.59?
    Much appreciate.
  2. Sanna1967
    Sanna1967 Senior Member
    Apr 1, 2014
    246
    Canada
  3. ASadani
    Apr 27, 2017
    151
    I have tried Reacue mode of the router to downgrade to the first version I believe to 384. The router wouldn't give access to the admin page even after the downgrade. The only way to make it work is to upgrade it back to the latest Merlin.
  4. ASadani
    Apr 27, 2017
    151
    Is there a reason the downgrade is not successful even though its being done through recovery? I even tried going down to the first official version and that too didn't start.
  5. Sanna1967
    Apr 1, 2014
    246
    Canada
    remove all usb devices if there are any , reboot, and retry
  6. ASadani
    Apr 27, 2017
    151
    There are no USB devices connected. I think there is a base firmware that takes it back to factory. Not sure which one it would be though. In ddwrt typically there is a factory firmware and then you go up from there. Confused here.
  7. ASadani
    Apr 27, 2017
    151
    With the attempt to downgrade, I even tried the initial version of DDWRT and eventually bricked the router. I got a brand new replacement manufactured in 2018 which came with the new firmware and was unable to downgrade that as well.
    I believe going back down needs a separate code base. Any advise. help?
  8. Striker317
    Striker317 Regular Contributor
    Dec 18, 2015
    112
    What problem are you trying to solve?
  9. ASadani
    Apr 27, 2017
    151
    That version of firmware used to get me 80 mbps on Vpn. The new one gets me 30. It’s a fork. With Merlin I still get 80 but have range issues
