HW Acceleration Disabled <unknown>
Outcasst
Hi, I have 3.0.0.4.374.33 installed on my RT-N66U.
I have made sure all of the related options are disabled in order to enable HW Acceleration, however I'm still getting the error shown in the image below.
Hey outcasst,
I have an rt-n66u running the same firmware and I don't get that error message or have an problems.
Have you considered resetting the router to factory defaults and reconfiguring it from scratch? Don't restore your old backup settings.
That usually means you disabled one of the incompatible features (such as IPTraffic) but haven't rebooted yet to re-enable HW acceleration.
This appeared to be the problem! Did a power cycle and it's disabled again.
Cheers!
How about QoS, I enabled it then did a reboot however the HW acceleration was still disabled.
As reported on that page, QoS is not compatible with HW acceleration.
The poster's problem was the opposite: he disabled an incompatible feature, but a reboot was required to ensure that HW acceleration got re-enabled.
