[ISSUE] RT-AC68U - Both wireless radios frequently disable.
Devante
Hey everyone.
I have this issue where my both 2.4 and 5 Ghz radios disable multiple times throughout the day.
I've been using the same version of Merlin for... well years really. Then the other day I noticed the wireless was disabled and have been dealing with it ever since.
I've tried updating firmware to 386.3_2.
I've tried power cycling.
I've tried leaving only one radio on, except enabling one will enable the other after a few seconds.
The only thing I haven't tried is going to the official firmware.
I'm not losing internet because all of my wired devices still work.
My wireless settings are below.
Thanks for any advice!
RMerlin
Asuswrt-Merlin dev
Two most likely reasons are someone is pressing the Wifi physical switch on your router, or you have a wireless scheduler configured.
Devante
Hey, thanks for the reply.
This router does not have a Wi-Fi physical switch and my wireless schedule has never been set. The settings I posted show this if you want to look at it for anything I might have set incorrectly.
And again, I haven't touched the settings nor firmware in a couple of years.
Thanks for any more advice!
ColinTaylor
Part of the Furniture
Look at the messages in the router's system log around the times the problem occurs.
OzarkEdge
And yet you are on the latest Asuswrt-Merlin firmware... maybe a reset to the firmware defaults settings and a fresh config would help.
OE
waeking
One thing that happend a lond time ago was lack of nvram. That created all sorts of havoc on my AC68u. I created a static.lease file and that alone helped alot in clearing out some of the nvram.
