Lost internet connection on mesh
vegetaleb
I built my 1st mesh today by connecting my ac86u to my modem by ethernet cable, then I connected my ac66u b1 as mesh node. Everything was running nicely with great speed, though out of the blue tonight things went weird, I had a download running on PC (via lan from the ac66u b1) but Internet was not working on WiFi, I restarted both asus but this time both wifi and lan stopped getting Internet.
I went to the ac86u settings. Internet was disconnected!
I could make it back by using dns 8.8.8.8 but it was extremely slow.
What happened and what are the settings that I should change?
vegetaleb
Weird things: torrent download work
And webpages open if I use a vpn!!!
What's happening? Why the router itself can't connect to Internet but vpn or torrent can?
Could it be that the modem's dhcp is still running?
bbunge
Part of the Furniture
Not sure if I would change any settings. Likely not related to the AiMesh.
First I would try another Ethernet cable between the AC86U and the modem. Make sure your firmware is up to date. AC86U is 3.0.0.4.386.44470 and the AC66U_B1 is 3.0.0.4.386.43129.
bbunge
Try another DNS upstream resolver like Cloudflare or Quad9.
