poontificate
Hey there. Anyone has an issues with Maximum Client/Devices connected to their Asus router simultaneously? My seems to be 30 even with a factory reset and the latest firmware.
I'm trying to go above 30 though. Once it hits 30, i'll need to disconnect a device before another can connect.No. 30 shouldn't be a problem.
The error message on the phones/computers is just a generic "unable to connect". No errors on logsys, the only logs out of the ordinary is:Shouldn't be a problem. What error messages do you get? What do you see in the router's syslog?
My submask is set as the default "255.255.255.0". Does it make a difference?What is your subnet mask? 255.255.255.224?
Your subnet mask is correct, leave it as it is. If you had set it to the one that sandman_1 mentioned that might have explained your problem.My submask is set as the default "255.255.255.0". Does it make a difference?
Another thing to look at: why 192.168.1.135 opens ports using UPNP that fast?
Log snippet you provided shows only 2 ports, but that's in 2 seconds and it carries the same session. What exactly do you run on that machine?
I would look for the reason.
Also, disable UPNP if you don't need it.
There's no obvious reason for the limit you're seeing. Even older models can easily manage 30 devices.
Welcome To SNBForums
