my asus router ((dsl-ac68u)) limit the speed for all the devices
lmxt99
hi
i have fiber connection 240/60
i made the asus dsl-ac68u as primary router for my house ((by ethernet cable cat6 and the wan mode on ac68u is Static IP))
i test the ethernet and its give me full speed 240/60
but when i connect to asus router it like limit the speed for all devices
my pc limit 220/40 my surface limit 80/20
another pc only 40
i disable Qos and enable it and nothing change
i did everything
pls aNY HELP
L&LD
Part of the Furniture
You're using a DSL capable router for Fibre (with an ONT connection)?
Is this a new purchase? Can you return/exchange it?
Are you running the latest firmware (you may want to have a look at @GNUton fork for the DSL-AC68U)?
Have you fully reset the router and minimally and manually configure it as a test (without using a backup config file to set it up)?
What other options, features, and/or scripts are you using on the router?
lmxt99
no its been with me for five years
yes latest firmware
yes i treid it
noting
maybe just Traffic Analyzer
i did some research and i found this
all windows devices have limit speed
when i tried on my phone and tablet i got the full speed on the same wifi
idk why and how fix it
L&LD
Okay, so 'which' latest firmware are we talking about?
Details on your reset would be helpful.
Traffic Analyzer may be the issue (and 'maybe' anything else you don't remember enabling).
lmxt99
3.0.0.4.386_39648-g788207a
i dont think the traffic analyzer the issue
cus when i reset the router before enable any features i test the speed and it was limit
i upload the CFG file may it help you
sorry but i cant speak english verywell but i will try my best
L&LD
A backup config file isn't helpful. Not human readable, afaik.
