newway
I recently upgraded router to a ASUS AX3000 (ax58u) to used as an AP for my home. I have separate 2.4g and 5g SSID.
(My main router has a different SSID).
I have noticed a strange behaviour that on some devices such as my android phone and my wife's iPhone. When we came home, my Android will show that I am connected to the Asus 5Ghz SSID, but with "no internet" message, and I cannot even open my router via the local IP (but my WiFi status shows I have the correct 193.168.1.xx IP assigned). On iPhone(12), the WiFi setting shows that it is connected to the ASUS's 5Ghz, but the status bar shows the phone is using cellular data.
On both phones, the issue can be resolved by disconnect/reconnect to the same 5Ghz SSID again (eg turn off WiFi/turn on again, or switching to 2.4g and back again).
This only happens to the 5Ghz network. And other stationery devices such as TV/Xbox/laptop seems unaffected.
On the router the WiFi is set to use WPA2-Personal and with 160Hz enabled.
Any pointers would be appreciated.
