Problem with AX86U transfers
Portalnet
Hello
I have FTTH 800/800 Mbits internet. Asus AX86U router, there are 3 WiFi-based laptops in the network (Intel ax210 and ax211) and a QNAP server via LAN. I have the band set to 160MHz.
Transfer:
LAN (qnap) - WiFi (ax210 or ax211) = 900 -950Mbits
LAN (qnap) - WAN = 750-800MBits
WiFi (ax210 or ax211) - WAN - 300 - 350Mbits ?????
What is the reason that every laptop over WiFi has such poor transfers over WiFi to the Internet? My router has default settings, I haven't changed anything. Why is WiFi-LAN 900Mbits and WiFi-WAN only 300Mbits? The same happens on the original Asus as well as on Merlin.
bbunge
Part of the Furniture
Hello
Transfer:
Do not force 160 MHz! Use the WiFi defaults. That means use Dual Band SmartConnect, auto channel on both bands and on 5 GHz use 20, 40, 80, 160 MHz. For a start do not use DFS channels.
My AX86U runs at 80 MHz over night but will switch up to 160 MHz when a 160 MHz client connects. Forcing 160 MHz will cause the 5 GHz to shut down if RADAR is detected.
Also go to the Intel website for the latest drivers for the AX210/AX211 cards.
Portalnet
I have the drivers up to date, the settings as you provided and the problem is there. Why is WiFi - LAN going full power and WiFi-WAN so weak?
bbunge
Do you have Wireguard enabled? If so turn it off and test again.
