Problem with Putty...
samuel
Hello, After installing Merlens 378.51 everything works except Putty. I can run the program and sign in but that's it. This is command I'm trying to run, wl txpwr_target_max and here is the response, wl: Unsupported.
Thank you for any help..
I can run the command on firmware .52_2 using Putty:
chief@RT-AC68U:/tmp/home/root# wl txpwr_target_max
Maximum Tx Power Target (chanspec:0x1806):      15.50  15.50  15.50
With kind regards
Joe :cool:
With kind regards
Joe :cool:
Thanks Joe, I willupgrade to 378.52..
That command will only work on ARM, you are executing it on MIPS model.
That's correct:
chief@RT-N66U:/tmp/home/root#  wl txpwr_target_max
wl: Unsupported
Thanks guys, it works on my AC68p and does not work on N66r routers...
Learned something new today....
Thanks again
