That is the maximum speed the router's CPU processing ability will allow.RT-AC66U
That number looks oddly close to 100 Mbps. Make sure the link between the router and the modem is at 1 Gbps and not 100 Mbps (can be checked on the Tools -> Sysinfo page). If in doubt, replace the Ethernet cable.
the AC66U has a single core 600Mhz 24Kc MIPS CPU capable of software NAT + QoS + Firewall speeds of 100Mb/s and a very heavy config (for bank use) of 30Mb/s. This is taken from real world performance setups and my own experience as well.RT-AC66U
380.69_2
This has been an issue in at last the past 3 versions that I have tried.
highly depends on configuration, the OP managed 115 Mb/s which is already above the 100Mb/s ethernet limit. Typical throughput around 100mb/s with a lean config around 300Mb/s.I've seen that model reach 150-175 Mbps in the past when CTF was disabled, that's why I wouldn't dismiss the possibility that the issue is the WAN port being only set to 100 Mbps.
Welcome To SNBForums
