query wireless stationlist
hautele
-> Gui "Wireless Log" - "Low Level Details"
Anyone knows if there is a way to get this information via console cli too?
I need to retrieve the wireless stationlist for some homeautomation tasks.
If there are other, better ways to get it, please let me know. I'm new to AsusWrt.
Thanks a lot,
kind regards
Jon
SSID: "NoBrain_2.4GHZ"
noise: -89 dBm Channel: 1l
BSSID: 7A:12:C9:CD:20:FF Capability: ESS ShortSlot RRM
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
HE Capable:
Chanspec: 2.4GHz channel 3 40MHz (0x1803)
Primary channel: 1
HT Capabilities: 40Mhz SGI20 SGI40
Supported HT MCS : 0-23
Supported VHT MCS:
NSS1 Tx: 0-11 Rx: 0-11
NSS2 Tx: 0-11 Rx: 0-11
NSS3 Tx: 0-11 Rx: 0-11
Supported HE MCS:
80 Mhz:
Interference Level: Acceptable
Mode : AP Only
Stations List
idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS BW Tx rate Rx rate Connect Time
1 FF:C5:D3:62:FF:C9 Yes Yes -61dBm n No No No No 1 20M 65M 39M 00:33:37
SSID: "NoBrain_5GHZ"
noise: -90 dBm Channel: 52/80
BSSID: FF:10:C9:CD:20:A1 Capability: ESS RRM
Supported Rates: [ 6(b) 9 12 18 24(b) 36 48 54 ]
HE Capable:
Chanspec: 5GHz channel 58 80MHz (0xe03a)
Primary channel: 52
Supported HT MCS : 0-31
Supported VHT MCS:
NSS4 Tx: 0-11 Rx: 0-11
Supported HE MCS:
80 Mhz:
160 Mhz:
Mode : AP Only
DFS status: state In-Service Monitoring(ISM) time elapsed 81000ms radar channel cleared by DFS channel 52/80 (0xE03A)
Channel Information
Channel 36 A Band
Channel 40 A Band
Channel 44 A Band
Channel 48 A Band
Channel 52 A Band, RADAR Sensitive
Channel 56 A Band, RADAR Sensitive
Channel 60 A Band, RADAR Sensitive
Channel 64 A Band, RADAR Sensitive
Channel 100 A Band, RADAR Sensitive, Passive
Channel 104 A Band, RADAR Sensitive, Passive
Channel 108 A Band, RADAR Sensitive, Passive
Channel 112 A Band, RADAR Sensitive, Passive
Channel 116 A Band, RADAR Sensitive, Passive
Channel 120 A Band, RADAR Sensitive, Passive
Channel 124 A Band, RADAR Sensitive, Passive
Channel 128 A Band, RADAR Sensitive, Passive
Channel 132 A Band, RADAR Sensitive, Passive
Channel 136 A Band, RADAR Sensitive, Passive
Channel 140 A Band, RADAR Sensitive, Passive
Stations List
86:5B:52:71:FF:FF Yes Yes -63dBm n Yes Yes Yes No 1 40M 120M 6M 00:01:31
ColinTaylor
Part of the Furniture
There are many threads discussing this. Try using wl -i eth6 assoclist, adjusting eth6 to match whatever WiFi interfaces you're interested in.
hautele
Thanks for your reply - it helps.
i will check wl out - seems to be a very comprehensive tool
jon
