Hi there,
I just bought an RT-AX86S router and installed the latest firmware 3.0.0.4.388_20566.
This router should be capable to support up to 3x3 spatial streams on 5GHz. But when I look at the wireless log details I can see that only 1x1 is supported and all my wireless clients just connect with number of spatial streams (aka NSS) equal 1.
Which setting on the router has to be changed to enable NSS up to 3x3 ?
Here is wireless log:
SSID: "1234"
noise: -88 dBm Channel: 11
BSSID: 7C:10:C9:CD:06:F8 Capability: ESS ShortSlot RRM
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
HE Capable:
Chanspec: 2.4GHz channel 11 20MHz (0x100b)
Primary channel: 11
HT Capabilities: 40Mhz SGI20 SGI40
Supported HT MCS : 0-7
Supported VHT MCS:
NSS1 Tx: 0-11 Rx: 0-11
Supported HE MCS:
80 Mhz:
Interference Level: Acceptable
Mode : AP Only
Stations List
idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS BW Tx rate Rx rate Connect Time
SSID: "1234"
noise: -85 dBm Channel: 100/80
BSSID: 7C:10:C9:CD:06:FC Capability: ESS RRM
HE Capable:
Chanspec: 5GHz channel 106 80MHz (0xe06a)
Primary channel: 100
Supported VHT MCS:
Supported HE MCS:
80 Mhz:
160 Mhz:
Mode : AP Only
DFS status: state In-Service Monitoring(ISM) time elapsed 11250ms radar channel cleared by DFS channel 100/80 (0xE06A)
Channel Information
Channel 36 A Band
Channel 40 A Band
Channel 44 A Band
Channel 48 A Band
Channel 52 A Band, RADAR Sensitive, Passive
Channel 56 A Band, RADAR Sensitive, Passive
Channel 60 A Band, RADAR Sensitive, Passive
Channel 64 A Band, RADAR Sensitive, Passive
Channel 100 A Band, RADAR Sensitive
Channel 104 A Band, RADAR Sensitive
Channel 108 A Band, RADAR Sensitive
Channel 112 A Band, RADAR Sensitive
Channel 116 A Band, RADAR Sensitive, Passive
Channel 120 A Band, RADAR Sensitive, Passive
Channel 124 A Band, RADAR Sensitive, Passive
Channel 128 A Band, RADAR Sensitive, Passive
Channel 132 A Band, RADAR Sensitive, Passive
Channel 136 A Band, RADAR Sensitive, Passive
Channel 140 A Band, RADAR Sensitive, Passive
Stations List
E6:46:A1:AC:86:46 Yes Yes -70dBm ax No Yes No No 1 80M 324.3M 272.2M 00:00:08
F8:FF:C2:50:21:31 Yes Yes -65dBm ac No Yes Yes No 1 80M 433.3M 325M 00:00:09
A2:D7:1C:F8:17:A8 Yes Yes -79dBm ax Yes Yes No No 1 80M 408.3M 6M 00:00:09
