sinshiva
Quick guide to make use of a better HOSTS file on some Asus routers. A better explanation of the HOSTS file can be found here, but essentially using a customized HOSTS file helps filter advertisements and prevent users on your network from connecting to some known sources of malware. This can help speed up browsing significantly on smartphones, etc.
At the router's configuration page, at Administration > System, enable the Telnet server.
Using your preferred telnet client (PuTTY), login to the router using your set credentials. After logging in, you'll need to enter the following commands.
cd ~
wget http://winhelp2002.mvps.org/hosts.txt
mv /etc/hosts /etc/hosts.old
mv hosts.txt /etc/hosts
logout and reboot the router from the webadmin. isn't this router awesome? perhaps remember to disable the telnet service when you are done.
cd ~
