I just got an ASUS RT-AX86U wireless router. I'm working on getting everything setup on it. I can't get my ring doorbell 2 to connect to this router. The doorbell was working fine with the other router. Last summer I helped a friend with a similar problem with his netgear router where the Garage door wouldn't connect, that issue ended up being a compatibility issue with AX wireless. After disabling the AX, it worked fine. I suspect my issue is probably the same, but I have yet to find the right options to disable to make it work. Would any one have have any better insight on this?
