slurmsmckenzie
Hello, I was considering getting an RP-AX56 to add to my current AiMesh system (RT-AX86U plus wired XD4 satellite) to improve the signal for a SolarEdge inverter which has been mounted on an exterior wall.
Research reveals a lot of issues seen earlier this year with this model (e.g. https://www.snbforums.com/threads/asus-aimesh-node-rp-ax56-keeps-disconnecting.85031/ - there are many others on other forums) but I couldn't find anything more recent to get an idea of whether this was still a problem at this point?
Any thoughts on whether I'd be likely to see issues buying a new RP-AX56 would be most appreciated. I plan to use it as a wireless node with 2.4GHz only and it will be at a good distance from the existing router and node.
